For the first session of actually building the micro-plate reader, we started with the general structure of the micro-plate reader. We built the bottom and the supporting stands on the sides. It was sort of like building Lego pieces, only that we had to be more meticulous and to consider more about the distance between each piece. Afterwards, we experienced the technology of laser cutting and then we worked on transforming the origin distance of the pieces of the guide to our own version, since some of the materials we used had different dimensions when comparing to the original layout.
