To keep the design simple I decided to adjust the time only with a serial command.
Most of the logic comes from the DS3231_set example code.
The Arduino listens on the serial connection with 9600 baud.
It accepts the following string:
YYMMDDwHHMMSSx
YY= two digit year (example '20')
MM=two digit month (example '10')
DD=two digit day (example '26')
w=separator
HH=two digit hour (exampel '19')
MM=two digit minute (example '10')
SS=two digit second (example '20')
x=sparator at the end
Full example would be:
201026w191020x
for the 26th of October 2020, 19:10:20
To set the date with a Linux computer just type:
stty -F /dev/ttyUSB0 -hupcl
echo -n "201026w191020x" > /dev/ttyUSB0
Jelto
