Well, it's reading files I import. Which is good. Now I just need to make them parse...
And here's what was failing:
class Lexer {
File file;
String buffer = "";
int line_number = 0;
Lexer(File file) { // line 10
this.file = file;
.... more code ....
It's the constructor. I forgot to put a access restriction like 'public' or 'private' on it. My parser must think it's manditory. Debating weather it should be.
One thing I don't care for in Java is that the default access has no keyword. It's not *bad* but it seems like better code would be produced by requiring one. Just thinking.
