Overclocking the Turbo CPU - attempt 1
A project log for MSX COMPATIBLE BOARDS FOR RC2014
Create a series of boards designed for the RC2014 bus to achieve MSX/MSX2 compatiblity
dean-nethertonDean Netherton 02/17/2026 at 08:070 Comments
(This post is mirrored on my personal site at: https://www.dinoboards.com.au/2026/02/17/overclocking-turbo-cpu-1.html)
My Turbo CPU (both the Yellow and Stegosaur versions), run a stock Z80 at its maximum officially supported speed (for the DIP40 version) of 20Mhz. As mentioned in previous posts, the Turbo CPU runs the CPU at 2 different speeds - the slow standard speed when accessing I/O devices (such as the VDP or SIO/2 modules). And the boost speed (20Mhz) when accessing memory or crunching instructions.
To date, any attempt to ‘overclock’ the CPU, resulted in non-operation. I didn’t think this was a limitation of the CPU so much, rather a limitation of the logic chips I use to switch between the 2 clocks.
If the CPU is running at its high turbo speed, and attempts to initiate an I/O operation - then the logic needs to activate very quickly to stretch and sync up with the slower clock. If it doesn’t get the speed of the CPU down quickly enough, then the targeted I/O device might not see the incoming request from the CPU - or have sufficient time to respond.
Nonetheless, I thought I would have another look to see if I could get some more ‘performance’ from this module - and I ended up discovering a couple of things:
  1. The system did not always seem to downgrade to the standard speed when doing I/O operations!
  2. The overclocking issue was perhaps due to the timing of the generated WAIT signals - and not related to the clock speed slow down challenge.
I had a bug
When I looked at the clock signal and IORQ signals on my oscilloscope - I was very surprised to see the clock speed did not seem to slow down every time the CPU issued an IORQ request - I struggled to believe my eyes - how did this not cause reliability issues? I can only assume it was infrequent enough to not manifest in my specific hardware and testing.
It seems on close inspection, when the Z80 is doing an IORQ write, the duration of the IORQ is sometimes too short for the clock slow down system to activate. Reads seem to always trigger the slow down.
Lets have a look at some traces of the situation:
I/O Read Operation:Timing Trace of IORQ and CPU CLOCK
The above trace shows the CPU Clock (blue) going from its fast rate to slow rate, when the IORQ (purple) goes active low.  There after, the clock stays in the slow rate (for a total of 31 ticks).  The green trace is the RD signal - indicating that this is a read operation.
I/O Write Operation:Timing Trace of IORQ and CPU CLOCK
This trace shows a similar transition - but this time for a I/O write operation (green RD is in-active HIGH)
I/O Write Operation (without slow down):Timing Trace of IORQ and CPU CLOCK
And this trace shows the fault. The clock has briefly 'stretched' during this I/O write, but the clock did not transition to the slow rate.  I am not sure why, or if its even related, but the IORQ (purple) goes low at a different point relative to the clock (blue) phase - it seems to be a fraction later than the previous trace. This small delay seems to be enough to fault the clock slow down system.
Despite not observing any reliability issues, I thought it was best to fix this.
What was the cause?
Now to understand the cause, we need to dig a little into the design. In the Turbo CPU module there are 3 main logic systems that work together.
  1. WAIT State Generator - this is implemented in a PLD and generates WAIT states for the CPU, based on the position of the speed slider switch.
  2. BRAKE State Generator - this is implemented in another PLD and generates a signal that selects which clock to use (the Turbo 20Mhz clock or the standard slow clock). It also incorporates a counter to hold the CPU in the slow mode, for 31 clock cycles.
  3. Clock Switcher - this is implemented with a couple of TTL chips - and its responsible for delivering the appropriate clock signal to the CPU - and ensuring a clean switch over from one to the other.
Turbo CPU Block Diagram
Now the 2 PLDs mentioned need to have their own clock signals to drive their logic. The WAIT State Generator is driven by the current active CPU clock. So it might be the slow or fast clock - depending on the current active speed. The BRAKE State Generator is driven by the SLOW clock always.
The problem arises when the CPU is running at its high speed and generates its IORQ signal. Given the BRAKE State Generator is driven by the slower clock, it will take a bit of time before it fully latches the BRAKE signal.  And sometimes the timing and phase difference of the two clocks would mean that the BRAKE signal does not get latched before the CPU has finished its IORQ operation - thus it never switches to the slow clock speed for the required 31 clock ticks. (At least, thats what I think is happening!)
The Fix
The best fix, that does not not require any hardware changes, is to update the WAIT State Generator to produce an additional WAIT state for IORQ requests. This change will extend the time of the IORQ periods slightly, enabling the BRAKE State Generator to respond in time.
In the original PLD code, there is the following bit of logic, that determines when a WAIT signal is to be generated.
MR = (MODE_NORMAL & MREQ & !RFSH & M1)
   # (MODE_MIDDLE & MREQ & !RFSH)
   # (MODE_FAST & MREQ & !RFSH);
This code was changed, as below, to now also generate a signal WAIT state when an IORQ operation is requested.
   # (!MODE_NORMAL & IORQ);
# is OR & is AND MODE_XXX is the position of the slider switch
A simple fix. The following capture from my scope, shows the CPU clock rate (in blue), transitioning to the slow rate, when the IORQ (purple) trace goes active low. And it now always seems to correctly transition.
BLUE TRACE - CPU CLOCK
PURPLE TRACE - IORQ REQUEST
But I still could’t overclock the system beyond the 20Mhz rate – I did eventually - but will leave it to the next post to describe how.
