My two laser-related projects have merged into one. After making a new pendant that mounts to the machine, I combined the monitoring and leveling systems into a single unit running off a Teensy LC. This means there is now just one display for everything. It also helps make all the wiring cleaner...it even has a USB port on the pendant so I don't have to open the side of the machine to do programming.
I added files for the pendant board (FreePCB source files & gerber files), the pendant itself (STEP file), and the custom keycaps I designed (also a STEP file). New code (ino file) also uploaded.
The next step will be upgrading to a RasPi Pico. I designed a new mainboard for this task and it's currently on the way from China.
