I finally gave in and ordered some pro mini's
Currently redesigning some parts after learning from mistakes in my current version.
One big thing I forgot is how I will hold all the parts together so in this version I will be sure to add some screw holes (want to avoid glue).
Will need to make the housing taller since the pro mini now comes into contact with the encoder.
I will publish a more detailed log showing the changes I made when I am finished
