2020-12-12
Bought this from the Pi Shop for £25.
https://thepihut.com/products/inky-phat
This might be useful in battery-powered equipment, to show data like when a battery was last fitted, and how much estimated battery life is left. This will remain on the screen even after a battery has died. There are situations where a dead battery can result in a dead user!
The box has a link to http://pimoroni.com/inkyphat, which links to installation instructions at https://learn.pimoroni.com/tutorial/sandyj/getting-started-with-inky-phat
The software can be installed by the command line
curl https://get.pimoroni.com/inkyphat | bash
This collects the script from the web url and pipes it to the bash command.
It is a very long script, and several times reported:
"Some packages could not be installed, review the output for details!"
I ran the demos anyway, seemed to work fine.
Total installation time very short, mostly installation script working.
Key points:
- The display is almost as big as the PCB, so take care how you push it onto the header.
- The demo font is awful, this is not a bug
Keith
