avrdude 6.3 comes with a bit-banged GPIO driver that is suitable for use with this hat. All you need to do is add this to your avrdude.conf file:
programmer
id = "pihat";
desc = "Use the Linux sysfs interface to bitbang GPIO lines";
type = "linuxgpio";
reset = 25;
miso = 9;
mosi = 10;
sck = 11;
This works, but there is a higher performance variant of this that actually uses the Pi SPI bus. To use it, you must first enable SPI in raspi-config. Once this is done, you'll see /dev/spi0.0 show up. Apply the patch (see below) to avrdude and then add this section to your avrdude.conf file:
programmer
id = "pihat";
desc = "Use Linux SPI device in /dev/spidev*";
type = "linuxspi";
reset = 25;
baudrate=100000;
The patch to avrdude is here. This patch also adds support for using the TPI adapter for TPI programming.
