The to do list for this project is getting smaller and smaller. There are few more things left to do:
- Replace RPI 3 with 4 and properly mount it
- Connect the microphone (I was wrong about audio input, so i ordered USB sound card)
- Make electric front door (This will become a new project)
- Print screen bezel (Transparent PVC foil overlay)
- 3D print recessed housing for IEC power connector, so it doesn't stick from the back of the cabinet
- Make new cabinet back (Laser cut .75mm galvanized steel sheet)
