So I finished #Turbot Keyboard and while it is a fine keyboard, it turned out to be less convenient to me than the #Dorsch 48k Keyboard. The reason for that is that it's too big, meaning that I have to move my hands to reach keys like Esc or Backspace. Turns out that a large part of the magical touch-typing improvement I got with the Planck layout is not from it being ortholinear (though it certainly helps a lot), but from it being so small, that you don't move your hands sideways.
Once I realized that, the solution is obvious: I need to take the Planck, break it in two so that I can have my hands farther apart, and add a number row, so that it's easier to program with it. So I went to the keyboard layout editor and made this:
From there it was the usual process, I made a PCB with a SAMD21 MCU on it, and ordered it:
The switches were on order already. I also found another set of keycaps that are compatible with the low-profile switches, and ordered them too. Today everything arrived all once, so I began assembling.
The keycaps turned out to be a little bit too high and too small for my preference:
So I swapped them with the PBT keycaps I had on my #Flatreus Keyboard:
Then I had to use a few transparent key caps I had lying around, because I didn't have enough of the PBT ones:
Once I had the keyboard all programmed and working, and I knew it's going to replace my Planck as my daily driver, I decided to swap the key caps with the Planck, so that now both of them have consistent keycaps:
And that's pretty much it. I'm using that keyboard right now and it's great so far. I will probably keep it for a long time.
