A busy/free desktop indicator for the Adafruit Circuit Playground Express.
Button A increments the busy indicator by 15 minutes on each press, button B decrements it by 15. Once the timer has lapsed, the indicator goes back to blue.
You can shake to clear the timer, and the switch toggles the lights on or off.
Bring in the New Year in style... the Holiday Wreath shader has been replaced with a Fireworks shader! See the sparkling explosions from the safety of your desk.
Added a new holiday wreath shader to celebrate the holidays!
Also, I've tested the Busy/Free Desk Indicator with CircuitPython 6, and it doesn't like having the Circuit Playground's filesystem mounted in read-only mode. If you would like to use CircuitPython 6 then omit boot.py when installing the software - otherwise stick with CircuitPython 5.3.
