A jigsaw-style customisable robot maze system. Components sized to work with bit:bot, STS-pi and MiroBot.
Can create a PiWars 1500mm square arena too!
Designed to be laser cut from 400x600mm sheets of 4mm mdf
Files
base 2s.dxf
You'll need 2 of these to make up a 1500mm square arena
