Internal logging is now fully functional, producing a log file every time the app is run and saving important events. By default, last 3 run logs are saved on the disk and rotated on every app startup. Should help with future debugging.
CI pipeline for ubuntu release was not include a libpng12 dependency, failing to run precompiled ubuntu package on anything apart from Ubuntu 16.04. Also fixed
Vedran
