After a bit of break from the project Im back into it.
The Bluetoooth Module The Microchip RN52 has arrived along with a few MCP2515 based CAN interfaces fro testing.
Ive just set up a test bed Raspberry Pi with MC2515 adaptor attached (what I Was suing to talk to the car originally - this allows me to display can Messages via CANdump and send send comands individualy with CANsend or send a log file with CANplayer.
To Bring up CAN interface on the pi need to
sudo /sbin/ip link set can0 up type can bitrate 125000
For the time beign Ill be using a UNO clone and MCP2515 module for the busines end.
The UNO is connected to the MCP2515 board
| UNO | MCP2515 |
| 2 | INT |
| 10 | CS |
| 11 | SI |
| 12 | SO |
| 13 | SCK |
| Gnd | Gnd |
| 5V | VCC |
Saabman
