Turning an old PS/2 number pad into a Bluetooth macro pad for my iPad.
The parts came in the mail today!
From left-to-right:
A Fellowes 17-key number pad with PS/2 port.
A no-name 500mAh 1S lithium-polymer battery from Amazon.
A Sparkfun Artemis Nano microcontroller.
The microcontroller is really powerful for its size. According to the manufacturer, it can even run TensorFlow Lite models for voice recognition, etc. I chose it because it had several must-haves: native Bluetooth LE support, native Li-Po battery management, and was small enough to stuff into the case of the keypad.
I think I set a new speedrun record in the Smoke% category. Less than half a minute after unboxing the controller, I plugged in the Li-Po and immediately smelled burning silicon.
My thought process went something like this:
The Artemis Nano's got a JST socket. The battery's got a JST plug. Should work.
Turns out all the fancy one-way keying on the socket doesn't do jack-shit if the plug is crimped backwards.
Lesson number one: NEVER TRUST THE CONNECTOR.
I unplugged it fast enough that the charge controller most likely survived. I'll rewire the Li-Po tomorrow, and hope nothing else blows up.
- TK
