Small teensyduino example added
A project log for AD849x breakout board
I wanted to try OSH Park, so I designed a simple breakout board for the AD849x thermocouple amplifier ICs.
christophChristoph 08/23/2014 at 17:360 Comments
I've added a small example to the github files. While it's written for teensyduino running on a Teensy 3.0 or 3.1, it shows how easy to use the amplifier is. It should be no problem to port it to other architectures for anyone who has used a microcontroller's ADC before.
I used it to measure the temperature of my laptop's outlet air (57 °C):
A close-up of the connections:
-, Ref, and Gnd are tied together for single supply without any shift in the output. The yellow wire is Out and goes to the Teensy's A0 input, and + is connected to the supply. Simple!
^ Going up? ^
Rich text editor
