The device was intended to be helmet mounted, and to use Wi-Fi to notify the software part of the system about detected point. There are two connections from the device to the fencing hardware, one to the foil and another one to the suit (mask). Inside of the device, there is a battery, some LED's and a buzzer. LED's are bi-color so each contender can be assigned with its own color. When the point has been detected, LED's start to flash and buzzer becomes active. PCB was designed as a flex-rigid PCB, so that LED's could be mounted on the side of the device.
Nikola Secerovski
This project is nice. Chain-link fencing is a common option for commercial enterprises and residential applications because of its durability and resistance to weather. A chain-link fence is beneficial for preventing unwanted pests and visitors from entering your home's yard. Call https://longviewfencecompany.com/chain-link-fences/ right now to arrange your chain-link fence installation. They can assist you with your next fencing project because they are one of the top Longview fence companies in the region.
