I'm going to squeeze a Commodore C64 satellite tracking system from 1987 into something the size of a bar of soap
The zoom floppy USB interface is on order.
My initial enthusiasm upon discovering the stash of old units has been dampened by a sudden and unfortunate memory. While I'm not 100% sure, I think the programs were distributed in a compiled format (there were two programs, one for satellites, and another one just for terrestrial antenna pointing based on the remote station's radio callsign prefix). I don't think this was done for copy-prevention reasons, but rather program speed. My recollection is vague, but I think we discovered that the compiled program ran faster and/or loaded faster. With normal languages, that makes sense, but I'm not sure how Basic was compiled.
Regardless, I will proceed and try to get the floppy images extracted to a more modern media for analysis. And continue racking my brain and see if I can come up with any place to look where the source code might be stored.
My son dug up a trove of old Autotracker stuff. Now I need to get started.
Yes. However my plan was to reproduce as faithfully as possible the original. The stumbling block has been the original software, but I’m 90% sure I’ve tracked that down (pun intended). It’s being held for me and hopefully once this Covid dies down I can arrange to pick it up.
The original rotor interface was simple and dumb — open loop control using relays. I’m pretty sure I can squeeze the necessary relays into the space. And because of the modern and lower cost electronics, I’m pretty sure I could upgrade the system to accept feedback. In fact, I have a vague recollection that feedback was in the software but just not used.
I have not messed with the old school rotator control stuff. I remember from the 1970s, it was some wierd, clicky, electromechanical thing. I just used a variant of the EZCom protocol on a serial interface for the rotators that I have built.
KE7FEF
Seems like a Raspi or a Beaglebone running GPredict would satisfy the size and loading requirements. Depending on your rotator interface, the rest might be as simple as an RS232 level shifter.
