2020-11-16
Downloaded libft4222-linux-1.4.4.9.tgz and unzipped it. Ran the command:
sudo ./install4222.sh
and got no complaints.
In the examples/get-version.c file, there are instructions for Linux:
cc get-version.c -lft4222 -Wl,-rpath,/usr/local/lib
sudo ./a.out
It reports no devices found. So now I need an FT4222 module to play with.
2020-11-17
I read that Linux can use the I2C interface in the VGA port. This could bypass the need for a USB-to-I2C module.
https://blog.atx.name/twilight-vga-i2c-breakout-board/
Ran a command to list the I2C adapters, and ten were reported.
ls /sys/class/i2c-adapter
i2c-0 i2c-1 i2c-2 i2c-3 i2c-4 i2c-5 i2c-6 i2c-7 i2c-8 i2c-9
Tried to detect devices:
for i in $(seq 0 8); do sudo i2cdetect -y $i ; done
The program 'i2cdetect' is currently not installed. You can install it by typing:
sudo apt-get install i2c-tools
This installation command worked. Tried to detect devices again, but got permission denied. Had to become a super user with the 'su' command. This allowed devices to be detected. I don't have any devices attached yet, so all I got was ten lots of this:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I checked that my video card has a VGA output, as these are going obsolete. Fortunately, mine does.
Time to look for an old VGA cable...
2020-11-17
Ordered two UMFT4222EV-D modules from Mouser. Despatched from Germany, they arrived 2 days later.
2020-11-22
Compiled and ran the example code that gets the hardware version from the module. Success!
The I2C master example writes and reads a serial EEPROM. I have one but VCC is 5V, not the necessary 3V3. That code would simply prove the interface works. I shall examine the code and see how I could get it talking to one of the I2C slave modules I have.
2020-11-23
I had expected my USB-to-I2C module to show up as an I2C bus in the Linux file system., and wondered why it did not. On my laptop, I listed the busses found like so:
i2c-3 unknown i915 gmbus panel N/A i2c-1 unknown i915 gmbus ssc N/A i2c-8 unknown DPDDC-B N/A i2c-6 unknown i915 gmbus dpd N/A i2c-4 unknown i915 gmbus dpc N/A i2c-2 unknown i915 gmbus vga N/A i2c-0 unknown SMBus I801 adapter at 3040 N/A i2c-7 unknown DPDDC-A N/A i2c-5 unknown i915 gmbus dpb N/A
None of these have FTDI in the name. There is one with vga in the name, and two with DDC in the name. I could scan those buses, then attach an I2C device to the VGA port, and see which bus had changed. The easiest way was to connect my laptop to the VGA port of my monitor. No soldering needed!
My laptop LCD panel blinked briefly. If I go to the system settings, it now knows it has two displays. Even if my desktop monitor is in use through its DVI port. I also see that devices appear at addresses 30, 37, 4a, 4b and 50 responded on i2c-7 (the DPDDC-A bus). 50 is the configuration ROM.
sudo i2cdump -y -r 0-127 8 0x50 b
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 00 ff ff ff ff ff ff 00 10 ac 79 a0 53 59 43 30 ........??y?SYC0
10: 05 1d 01 04 a5 34 20 78 e0 ee 95 a3 54 4c 99 26 ?????4 x????TL?&
20: 0f 50 54 a1 08 00 81 40 81 80 a9 40 b3 00 d1 c0 ?PT??.?@???@?.??
30: 01 01 01 01 01 01 28 3c 80 a0 70 b0 23 40 30 20 ??????(<??p?#@0
40: 36 00 06 44 21 00 00 1a 00 00 00 ff 00 59 50 50 6.?D!..?.....YPP
50: 59 30 39 31 54 30 43 59 53 0a 00 00 00 fc 00 44 Y091T0CYS?...?.D
60: 45 4c 4c 20 55 32 34 31 32 4d 0a 20 00 00 00 fd ELL U2412M? ...?
70: 00 32 3d 1e 53 11 00 0a 20 20 20 20 20 20 00 c0 .2=?S?.? .?
I now know that I can use the Linux i2c tools to access I2C devices through the VGA port. You may have to do it with sudo but at least it is possible.
Windows does not want you messing with the VGA I2C bus, lest you corrupt the EEPROM containing the VGA type information. I shan't bother trying to do it through Windows.
The FTDI USB-to-I2C/SPI modules seem the most practical system that can be accessed from Windows and Linux. They don't appear as Linux I2C busses, probably because the FTDI modules have more functionality that a Linux I2C bus. For example, they need commands to configure the module as I2C, SPI or GPIO, and other details. So they have to be accessed through the FTDI application programming interface, in the C language.
Well, that is some useful stuff learnt today.
2020-11-27
FT4222 library example code running. Reading and writing EEPROM through level shifter.
2020-12-01
FT4222 module reading and writing the 16-bit I/O chip (MCP23017).
