2020-11-20
Windows 10 driver installation.
After wading through documentation, this was very easy.
Some documentation said that all you need to do is plug the module in and Windows 10 would install the software. I didn't get the expected pop-up windows saying 'new device detected'.
Fortunately the documentation said you could install the drivers simply by running a single setup.exe program. I did this without problems.
The module is now visible in the device manager, as a USB device with two FT2223 ports.
