Of course you could just use a standard Textool dip test socket, but this is boring and brings the risk of rotating it 180°. So I measured the top plate of a Textool socket to print a new customized top plate on a SLA Printer. Not needed contact are removed and holes are nicer fit for the round pins.
![](https://cdn.hackaday.io/images/7442711612663517763.jpg)
![](https://cdn.hackaday.io/images/8960731612663531770.jpg)
![](https://cdn.hackaday.io/images/9324001612663544097.jpg)
The extra hole is for the a extra test pin, This need for rev2 PCBs, but ore on that soon.
