How to quickly test a ESP32-PICO-D4 Arduino module code and than a ESP32-S2 Micropython module with the latest Adafruit STEMMA-QT Sensor or just fiddle something new on a breadboard ?
SNAPZZ-ESPerimenter allows to quickly test different MCU modules with a breadboard, tinker, measure, test, document and verify.
ESPerimenter features a Quick-SNAPZZ Release Lock, that snapz and releases modules quickly.
At some point i retired the "old" (red) ESPerimenter board and morphed it into the ESPIrimenter (blue PCB).
It's more compact, holds the "PICO SNAPZZ" modules (22x22mm) modules only. But also it breaks out ALL "SNAPZZ M2 gen.2" Pins to Breadboard Pins - that is over 40 !!!
