Putting Together the Enclosure
A project log for Digital Christmas Countdown
Over-engineering the countdown to Christmas
scott-clandininScott Clandinin • 11/23/2020 at 14:57•0 Comments
I chose to 3D print the enclosure with built-in stand-offs for the Arduino Mega and RTC module. Autodesk Fusion 360 was used for Modelling. 3D printer was Craftbot Plus.
The small groove in the bottom exists to allow a screwdriver to pop out the faceplate if required.
The intention is to wrap the box in wrapping paper, so a top faceplate was designed as a snug fit to cover everything up.
