Industry IoT Gateway
Iot gateway supports CAN, RS485, Lora, Input and Output control
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
+ Using 24V power supply.
+ Support CAN protocol.
+ Support RS485 and Modbus protocol.
+ Support Lora and Input Output control.
+ Support MQTT.
+ Using ESP32 with IDF framework:
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/
+ Design for industrial field.
+ Using in Smart Home, Smart Farming, Monitoring and Loging CAN message on Car, etc...
=> If you want this project (Altium and source code).
Please contact via email: hydratech.iots@gmail.com
Facebook : https://www.facebook.com/ducthuana9/
