Lab Bench Power Supply with C.C and C.V
A simple Linear Lab bench power supply with variable 0-25V output and up to 2A of current.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is one of my hobby project I have done in the past, The power supply is capable of supplying 0-25v with up to 2A of current.
The power supply uses a transformer which steps down 230V mains to 24V, which is then rectified and filtered. The variable voltage and constant current is achieved by op-amp and power transistors.
