I built a small test circuit for the CD4026 decade counters and 7 segment LEDs and connected it up to Ben Eater's clock, which I built a while ago. All good, everything worked.
Next up: build the 1Hz crystal oscillator test circuit. After that, the counter logic reset circuitry needs to be tested and then I will be ready to move to PCB.
