I have built the 1Hz clock signal generator on breadboards, but I suspect that the value of the resistor used isn't accurate enough. I am using a 470K resistor instead of a 330K resistor. I have ordered some 330K resistors from Ebay and I will resume work in a five days, or so. It took me hours to discover this problem. *sheesh*
