After a long pause, I was finally able to get my hands on the project again. After some polishing, the design files are now ready to see the world:
https://github.com/renetec-io/cm4-panel-jdi-lt070me05000
Enjoy!
A project log for Raspberry Pi CM4 Сarrier with Hi-Res MIPI Display
An interface breakout board for Raspberry Pi Compute Module 4, permanently attached to a 7" IPS touchscreen display
Enjoy!
Igor - this is great news. Sounds like you've either finished or at least reached a point where some feedback could be gathered. I realize this is OSH, but just wondering if you'll be providing a source for purchasing units for those that want to test without doing the initial build/assembly..?
