Heat set inserts take two
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 12/03/2020 at 02:410 Comments
Just a follow up to my last insert post. I picked up some quality inserts and they work so much better than the cheap amazon ones.
The longer 12mm m5 insets take so much heat that they caused a lot of warping of the model. But the shorter 6mm inserts went in with minimal warp. Less is more in this case.
I picked mine up from initeq
