Just a follow up to my last insert post. I picked up some quality inserts and they work so much better than the cheap amazon ones.
The longer 12mm m5 insets take so much heat that they caused a lot of warping of the model. But the shorter 6mm inserts went in with minimal warp. Less is more in this case.
I picked mine up from initeq
![](https://cdn.hackaday.io/images/9343821606963215412.jpg)
