Auto Squaring
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 12/03/2020 at 02:450 Comments
I went ahead and did a writeup on how to get auto squaring working on the Dremel CNC. Just a note, if your using a clone CNC shield from eBay then you will loose the ability to control the spindle, but with a proper CNC shield, or a ramps board you can have it all.
https://docs.google.com/document/d/1KOMStGTb-w_KqlAyxvKoIVSi_9OebBm97TLjsE9GJBE/edit?usp=sharing
Let me know how this works out for you if you try it.
