Sad news, Dusty had a catastrophic implosion today, I'm afraid there is no hope for survival.
I guess the vacuum is too strong for the bucket to handle. It is probably made worse by the two different sized hoses I'm using causing a stronger vacuum draw on the bucket. I'm also using a lid with a seal on it, things may be better using a cheaper lid with no seal so some air can leak.
Anyway I'm going to use two buckets stacked together to try and add strength. If that does not work then I may drill a small hole in the lid to reduce the vacuum draw by a bit.
