![](https://cdn.hackaday.io/images/1927881619758923147.jpeg)
User Darko Kmet posted the above render of there new nozzle design in a forum I watch. It may not be clear from the picture but they have solved the issue of air leaking around the lens by making it a double walled setup so the top is fully sealed. This makes the outlet larger but it ensures all air goes in the correct direction. It is something to experiment with.
