It is time again to summarize future tests that I need to run.
- Test new wire crimpers out. I upgraded my cheap $10 crimpers for a cheap $25 set of crimpers, maybe they work better.
- Cut aluminum, in particular cut a corner touch plate out, if I can find a block of aluminum somewhere.
- Cut/engrave plexiglass. I have no ideas here, but I do have a scrap piece.
- Test my speed/feed calculator out and try to work up some reasonable speeds/feeds for various materials.
- Test the output of gcode ripper on my rotary axis.
- Pick up a diamond drag knife tool and try etching glass or metal.
- Look into a honeycomb work table for the laser bed.
- Make a proper drag knife bed.
- Come up with better drag knife software than fusion, or work out how to load large svg files into fusion without it choking.
- Add a removable dust shield across the back of the work area to reduce chips flying all over my shop.
- Look at a stronger box fan to see if we can improve fume extraction. Or investigate a more focused extractor.
- Put Loctite on all screws. I have rattled quite a few loose over the last year and a half. I should have done this initially.
- Reinvestigate laser focus for optimal cut depth, in particular work out of moving the tool over 0.5mm can lead to a deeper cut.
- Build a full size drag knife using a box cutter blade.
- Etch paint off of a tile and/or slate rock
- Try engraving on wood using the laser
- Try doing an inlay on wood using the v-bit.
- Try doing a 3D carve using a ball nose bit.
- Try doing an inlay with epoxy.
- Actually come up with a project to make!
