I took a vacation with my family's (yay!) and picked up a Rolife Tramcar TG505 laser cut wooden model as a small souvenir.
![](https://cdn.hackaday.io/images/3587201657077496330.jpg)
For the $15 I spent on it, it came with a lot of stuff. There were 5 sheets of laser cut wood and two pieces of Lexan along with the glue and sandpaper needed to assemble the model. It took the better part of a day to put together with me fiddling on and off with it as parts dried. It was a fun experience and it turned out nicely.
![](https://cdn.hackaday.io/images/4176981657077632807.jpg)
One of the sheets is 1 mm thick, 3 were 2 mm thick and one was 2.5 mm thick. They used a neat trick on the holes. When a part needed to pass through a sheet the hole was cut square, but when it needed to connect to a sheet the hole would be slightly rounded to create an interference fit. On parts where only 3 sides were available a small dimple was added instead. This allowed the model to hold together quite firmly without glue. I used glue anyway but I think it would have completely held together without any glue.
Anyway it is a fun little kit and they seem to have a lot of even bigger models. If your interested in laser cutters you can look to them for inspiration, or for a fun afternoon distraction.
