I have not been posting here much, but I have been busy working. I have been developing a small test utility for work on the side using processing. I needed a UI for this utility and processing does not provide one, so I turned to Cards_UI a slick simple little inline UI.
Unfortunately Cards_UI has not really been updated in several years and it had some bugs. So I spent some time cleaning it up and writing a simple test script to try out all the various UI elements. Here is the result of that. Feel free to use it if your interested, I maintain no rights to it, although the original author retains there rights I'm sure.
![](https://cdn.hackaday.io/images/1959621666149335952.png)
