I have replicated the profile of the old t-nut onto a 180mm chunk of 1-1/4" 12L14 round bar. Final dimension was snuck up to with 600 grit wet and dry, so it is a closer fit in the block than the original. Turned between centers.
Nothing more to do till the toolpost arrives.
