Using the code in one of the posts, I made a timelapse using my Nikon camera of some ice cubes melting. Since it is computer controlled and the files are copied back to a local PC, you could run this for days! You could also increase the resolution to 4K and beyond if you wanted. This video was then assembled with shotcut. Enjoy!
