Task list status:
- source boards
- test MTK3339 GPS module indoor fixing ability
- test SAMD21 direct digital synthesis (DDS) of a sin sync pulse with its 10 bits DAC.
- test SAMD21 hardware interrupts handling with the 1PPS signal
- buy a copy of AoE third edition
- research analog stage configuration
- order some LM358 (with extra magic smoke in them)
- move project home from Blogger (!) to Hackaday
- test waveform analysis on Kdenlive
- research NLEs handling of timecode metadata
- launch gitlab repository
- for firmware
- for PPSSoundmerge python desktop post-prod script
- final Arduino coding:
- code NMEA parsing on UART (use Adafruit lib?)
- code UTC time DDS FSK modulation to DAC
- desktop python coding:
- audio track analysis:
- sync pulse detection
- word decoding
- merge synced tracks with ffmpeg-python ⇦ I'M HERE
- analog stage:
- measure some input impedances (cam and audio recorder)
- implement reference voltage for true audio AC with LM358
- test mic level output
- test line level output
- test small speaker for acoustic coupling
Maybe I shouldn't reveal I've been researching this project for ten years! It would cast a shadow over my capacity to deliver... 8-) But you wouldn't have access to my treasure trove of related links...
The first traces of my journey are links kept on Delicious, now Pinboard: they are tagged smpte and date back to 2011. I later diversified my classification and introduced year after year more nuanced tags, here are direct links to them: (this is stratigraphic information paleontology!)
From now on, maybe the project will stall again... I'm back to school this January after a sabbatical semester (ducking down during COVID: I just can't stand doing zoom classes), we'll see.
Raymond Lutz
