Added 5 x 4pin pwm fan driver (I2C) EMC2305
A project log for THE GEM - Smart LED Grow Lamp[Light&heatsource]
Max 85amp - featuring CREE X LAMP
juan-antonio-sren-epJuan-Antonio Søren E.P. 12/14/2020 at 05:590 Comments
Added EMC2305 4pin PWM fan driver. The driver monitors the 4pin fans sense output, it ramps up and down based on internal algorithm. The IC next to is is a temperature sensor   MAX31725MTA+T  with a 150C rating and decent precision. So there is now 5 individually controllable fan PWM outputs with RPM feedback, controlled through I2C. The MAX-31725 temperature sensor has a fast response time, which will hopefully make it a good choice for intuitive LED control based on temperature and current consumption.
Rich text editor
