To raise the light up into the enclosure, some sort of air channel is needed. This channel will also serve as mounting bracket for the wooden enclosure. On the LED side, the channel/bracket will provide mounting holes for wire shielding.
A project log for THE GEM - Smart LED Grow Lamp[Light&heatsource]
Max 85amp - featuring CREE X LAMP
