Heating or cooling the heatsink is entirely dependent on current consumption and ambient temperature.
Looking at the heatsink, it is obvious, when pushing cool air across those fins, the air is gonna heat up. The above heatsink is for the small version 254mm long, 80mm wide, 40mm high.
Juan-Antonio Søren E.P.
