Finished the First Mold
12/16/2020 at 06:32 • 0 commentsThe first mold is finished. Welded 4 Plates for each side together and reinforced it with an additional metal-profile. Two bore-holes on each side will hold screws and springs for applying pressure on the plate. After having the mold on the table, it seemed very heavy. So I will change the metal-profiles a little bit and start a testrun afterward.
The main challange with the low cost 4 Plate solution is bending of the material during the welding process.
First half of the mold is done
12/12/2020 at 17:22 • 0 commentsOrdered 8 sheets 200x175mm. Four of these are welded together for one side. Found a few rods and welded them onto the plates to make them more stable in the pressing process and to prevent them from bending during the welding.
