SuperNight is a solution to all the issues I have found with LED dimmers while working in film and on-location lighting events. It plans to have 2x8A outputs for CCT control, 20kHz+ switching for video-safe operation, and WiFi control via ArtNet or sACN. A 5 Channel version (SuperNight 4) will be designed for RGBW Control.
Files
supernight2_bom_0.2.0.csv
Comma-Separated Values -
6.06 kB -
12/14/2020 at 17:50
I've been toiling on this for around two months now, and I just put in the PCB order and parts order today. Sometime early next week, Assembly and testing will begin.
The PCB features are as follows:
12V-24V Input voltage
8A per-channel (16A Max)
Programming / Debug header
i2c header for OLED display
Input Voltage monitoring
Mosfet temperature monitoring
The software stage will hang me up a little more. Between learning the ins and outs of the ESP-32 and designing a user interface, I expect that it will be a steep climb. Nonetheless, I hope to have some sketches soon of the flow of the menu system, and the case design as well.
