Since the Satran only sell as a kit, I put together this video showing step by step how to assemble it. I think its quite straightforward, but a video always helps. Check out the last minute or so and you'll see how the wifi setup works...
A project log for SATRAN - Satellite Tracking Antenna
Wifi-controlled, azimuth/elevation antenna rotator.
