Want more detailled PCB artwork on your PCBs? Try dithering!
XK6A.dipdiptrace PCB file; this design contains no pins and thus can be opend with the free 300pin versiondip - 9.86 MB - 12/27/2020 at 09:08 |
XK6A_2038_gerber.zipgerber files including order remarkx-zip-compressed - 3.02 MB - 12/27/2020 at 09:07 |
dithering source images.zipThis archive contains the images used for the dithering patterns, you can uses this as a reference for your design. The file names match the silk-screen markings on the PCB.x-zip-compressed - 58.16 kB - 12/27/2020 at 08:27 |
1_small.jpgEach square is 1x1cm, the sizes refer to the smallest feature size and the % is the covered or blank area. The resolution is better than expected, even 0.1mm lines are reproduced correctly.JPEG Image - 1001.38 kB - 12/18/2020 at 10:54 |
2_small.jpgThe checkboard pattern is designed to be a 50/50 ratio, but if you zoom in you can see the copper squares are connected, so it can double as a (bad) ground plane.JPEG Image - 1.16 MB - 12/18/2020 at 10:54 |
I've also seen dithering before, but never a controlled experiment like this. What settings did you use for your silkscreen graphics? If you need it, you can now download my original design files (images/ gerber/ diptrace pcb).
Thanks for taking a look and sharing your design
interesting. systematic. silkscreen from JLCPCB does not have enough resolution. dots are your best friend.
Cool experiment. I have actually seen the dithering method using dots.
(It is also called "halftone" method which the technique used for the newspaper printing press).
Your results look great and I may try the checkboard pattern next time!
I have tried halftoning before with Elecrow PCB.
I have written a page on it here:
https://hackaday.io/page/8839-elecrow-pcb-review-2020
