Polymaker HT PLA
A project log for How to win at 3D printing
Survival stories with an Ender 3. Sadly hackaday has no organization features.
lion-mclionheadlion mclionhead 06/12/2025 at 08:070 Comments
Polymaker High temperature PLA has been the long sought after win for lion applications, manely backflow incense burners.  They're particularly difficult because of the heat generated by cones.
Been using 260C nozzle, 55C build tak, no print cooling, 25mm/s speed all around, .4mm nozzle, .32 layers.  It has similar layer adhesion difficulties as PETG but has a much higher melting point than even 250C rated vintage PETG.  It should be a better match for most every PETG application because it bonds to CA glue.
It has the consistency of clay.  It might be infused with clay to increase the melting point.
The 1kg roll is shorter than normal PLA because it's denser.  1kg is twice the price of the cheapest PLA so definitely not a general replacement for normal PLA.
