The Eduponics Mini ESP32 board consist of the following onboard sensors and modules:
- ESP32-WROVER Microcontroller
- Water quantity, soil moisture and pump XH2.54 interfaces
- Tiny relay that is used for controlling the pump
- ON/OFF Switch
- 12 V DC Power interface
- USB Type-C programmable interface (UART)
- Reset Button
- Wake up button (can be used with deep sleep for interruption)
- RTC DS1307 Module
- BH1750 I2C Light sensor
- BME280 I2C Temperature, humidity, and barometric pressure sensor
- Extension for DHT11 / DHT22 sensor
- AT24C02 EEPROM chip
- IO Expansion pins to connect extra sensors or modules
Except that, the actual kit comes with:
- Soil moisture (custom made design, highly accurate)
- contact-less water quantity sensor
- submersible pump
STEMinds
Red Tuka
hms-11
Ai-Thinker
Narrow Studios
