The LC100A is a fairly popular and cheap LC meter available on aliexpress and similiar sites. It is advertised as an up to 1% accurate device (depends on range) with a resolution of up to 0.01pF and 0.001uH. Unfortunatly he device I received had errors up to 50% and was thus not usable at all.
Thanks to a comment on aliexpress I found out that the issue was low quality components for the LC resonance circuit, likely the manufacture substituted them because they were cheaper. I think the main issue was that the max frequency was well above the rating of the inductor, so it's effective inductance dropped and threw off the measurements.
I replaced the parts with the best I could find (part names below) and the performance is within spec now. During my research I found a manual and a low-res schematic; I've up-scaled the latter manually and have both files attached below. The pictures are watermarked to prevent the seller from using my pictures.
Mine was 4-6% off on lo caps, 20-40% off on high caps. After your mod, I get 40-300% off on lo caps, 1-4% on high caps. Duh! Used your exact parts. Replaced caps with Vishay 1%'ers and samo-samo. Any guesses?
Did you remember to zero before the measurement? This LC meter measures the DUT with an LC oscillator, and I replaced the critical parts with parts which are stable across a wide frequency range. If you have exactly the same parts, I have no idea that the issue could be.
Sorry for the late reply, hackaday.io's notification system is broken and I didn't get an email.
Yes, I did zero it out. Weird. I cannot find any problems with the board or wiring, and replaced the parts (I had ordered a few of each - cheaper) I got a friend who works on Vandenberg Space Force Base nearby, in their PMEL shop, to check all he components. All were within a couple % of ratings. Just my luck I guess. Good thing I am getting too old to do much now!
With such small values the parasitic inductance/capacitance will dominate and you'd need a much better setup overall. You'd be better of buying a suitable device in the first place.
i have this kits but ic stm broken. can you share firmware for replace new ic stm to me?
