I am adding a impact bar.
The new idea with back/front cover is to design around the impact bar. The back cover has an internal plastic structure and a outer molded CF cover. not a fan of the sharp intersection between top/bottom cover.
A project log for K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
